throttle adjustment
Old 10-07-2008, 11:34 AM
hockey8787's Avatar
hockey8787
hockey8787 is offline
Default throttle adjustment
does anyone know if their is a adjustment on the "09 ultra's
Old 10-07-2008, 11:41 AM
ramnj's Avatar
ramnj
ramnj is offline
I don't believe there is an adjustment. It's an electronic throttle.
Old 10-07-2008, 11:59 AM
hockey8787's Avatar
hockey8787
ok mine seems to rotate a ways before the rpm's start to come up just didn't know if this the norm
Old 10-07-2008, 12:13 PM
Windup08's Avatar
Windup08
Windup08 is offline
I'm not sure if there is anything you can do yourself, but the shop should be able to get the dead spot out if its more than just a very small amount. The bigger complaint I've heard about the TBW is that in 1st gear they can be kind of jerky...you hit a little bump and your right hand moves slightly causing unintended throttle increase, so there shouldn't be much play in it, at least there isn't in my 08.
Old 10-07-2008, 12:29 PM
hockey8787's Avatar
hockey8787
my wide glide was like that but the ultra is just the other way so maybe there is one
Old 10-07-2008, 01:25 PM
Ultrasweet's Avatar
Ultrasweet
Ultrasweet is offline
I think this is an inherent problem or characteristic of the FBW throttle. My 08' was the same way. If you roll it all the way to zero it has a flat spot in it. You will learn to adjust to this yourself. T.
LedBoots
08-29-2014 05:33 PM
conmore
02-02-2012 08:17 PM
blusmbl
03-15-2011 06:18 PM
sstlcm08
01-23-2011 12:20 PM
Stevehat
06-21-2007 11:26 PM
Quick Reply: throttle adjustment
