Oil Filter ?
#41
I researched the K&P filter and I liked what I saw. I know a mechanic that runs a shop, and he puts one on every bike that goes out his door.
It's flow rate is 7 times better than an OEM, easier on the engine because the oil pump doesn't have to work as hard, has a bypass valve in it (which won't come into play as often as an OEM filter because of the better flow rate at start-up), it comes in different style cases (black, chrome, or aluminum), has fins on the outside that help with cooling, and has a magnet on the element so you can check it out each oil change and find out things before major damage is done to the engine. It was expensive, but I don't care because it's a once in a lifetime expense, and it'll help my engine run better and longer.
Here's the link again for anyone interested in a good filter:
http://www.motorcycle.com/products/k...ter-71983.html
