True Duals
I have Rinehart True duals on my 08 SG, with a PC III fuel controller, AN air cleaner...yep you can in a matter of seconds have it so rich that you will need new plugs. Most (all good ones) fuel management systems have a range of adjustability that allows for tuneing from stock and up.
If I read your question ... you have a stage 2 setup now with a presumtion of stock exhaust? If you now go to true duals....it will be leaner, more air out. If this is the case I would retune to get more fuel in, i.e. richen it up.
my 80 cui ran great with a stage 2 setup from back in 1998 which includes se(k&n) air intake and breather adapter,a se-3 cam, se calibration cartridge( race tuner ), 41% larger fuel injectors, se-performance mufflers. I recently went to a fullsac true dual kit, and it seemed to run lean. Alright, I bought the Techlusion 1040 fuel tuner ( adj. pot ), and once installed was when The surging and hestation started ( tried a thousand different adjustments ). I took it right off the bike and I was still getting the same problem. Then I installed the Super Flow 2.25 slipon mufflers and got the same surging/hesitation. Then I re-installed the Techlusion fuel tuner, tried another thousand different variation of adjustments. Now it is a little better, the best performance was a ( medium ) type setting for addin fuel ( 3/3.5/4/4), less or more just made it worst. My plugs are showing very rich. the thing dosen't make sense to me.
