no premium fuel
Go ahead and put 87 in the scoot. It won't hurt it, and IF you get spark knock go down to some industral paint supply store, buy a gallon of Tolulene, add about 10% of it to the ratio of fuel you have and ride. Tolulene is MUCH cheaper than the octane boosters, does the same thing, won't hurt anything and doesn't contain any additives you don't need.
out here i run 100vp at the pump, no pop or anything... but maybe order vp gas and mix it with 87, i have tried many with good results, it is expensive, but i dont trust octane boosters... ms109? (vp) and mix with 87...
with the 103 kit, i can tell the difference between the gases, but the vp gases are really designed for bike with higher compression...
If your bike is stock it will be fine on regular. Only worry if it 85+F out as premium helps the cooling better. I know a guy with an 03 RK with 70,000 and he has never run premium and had 0 problems.
Regular burns hotter and actually makes your bike run better if its stock or not already leaned out from the factory like my 08.
