Just got done fighting for 3 hours to get................
Old 10-02-2008 | 08:27 PM
DrPlastic's Avatar
DrPlastic
Default Just got done fighting for 3 hours to get................
......the fasteners for the L/H saddlebag to line up with its mounts!
WTF!
There's got to be a better way!
Old 10-02-2008 | 08:30 PM
04harleyboy's Avatar
04harleyboy
Do you have a loose mount? Mine line up pretty well.
Old 10-02-2008 | 08:32 PM
vette's Avatar
vette
Hey at least you won
Old 10-02-2008 | 08:39 PM
r8rs4lf's Avatar
r8rs4lf
WTF!
Funny you bring this up. Just yesterday after lowering my EGS, I had problems getting the left side bag on. I tried to remove the pin and it wouldn't come out of the mount. Come to find out the groove that the pin has on the tip was enlarged so it would not allow me to remove the pin from the mount. I squeezed it closed a bit, but I probably should go and get another pin soon.
Old 10-02-2008 | 08:44 PM
DrPlastic's Avatar
DrPlastic
Exactly what happened to mine. I had to remove the mounts in order to install the detachable backrest and rack hardware. The R/S goes on real easy but the left was a real PITA!
Old 10-02-2008 | 08:46 PM
Comfortably Numb's Avatar
Comfortably Numb
Default ...
When I adjust mine I loosen off the mounts on the bike just enough so they'll move around, and then mount up the bags. Then I tighten up the mounts again, enough that they won't move when I remove the bags, then remove the bags and complete tightening the mounts.
CN
Old 10-02-2008 | 08:55 PM
leon anthony's Avatar
leon anthony
those pin are 10:95 each
Old 10-02-2008 | 09:05 PM
Garemlin's Avatar
Garemlin
-Take the bag off
-Loosen both mounts
-Put the bag back on and twist the pins until they lock
-Then tighten the mounts
-Tweak as necessary
While you are at it you might want to slide the bag back on the support bar as far as it will go. If it is too far forward it will rub the paint off of your side cover. Just an FYI.
Comfortably Numb
Default ...
....and I'm guessin' about $100 in Canada. (but that's for the pair) LOL
CN
Old 10-02-2008 | 09:53 PM
Javawave's Avatar
Javawave
Originally Posted by Monstermile
-Take the bag off
-Loosen both mounts
-Tweak as necessary
Thats how I did mine. Works very well.
Quick Reply: Just got done fighting for 3 hours to get................
