Master Cylinder and Bubbled Paint
Old 09-30-2008, 02:09 PM
Thirdup's Avatar
Thirdup
Thirdup is offline
Default Master Cylinder and Bubbled Paint
I see it on all-too-many bikes. The brake fluid has buggered up the finish on the control levers (master cylinder seepage). I've seen polished aluminum eaten up, paint peeled off, etc.
HD OEM controls are painted black. Mine bubbled up sometime right after the 1000m checkup (of course this isn't a warranty issue). Looks like hell (oddly, it's just the master cylinder section....the switch housings are fine).
I actually like the black look. I don't really want chrome controls or chrome switches (nor do I want to pay HD another $500 for something I feel should have come from the factory with the ability to resist being eaten by it's contents).
Are there any other options? Will powder coating stand up better than re-painting?
Old 09-30-2008, 02:48 PM
dbuff's Avatar
dbuff
dbuff is offline
I have an 07 also and mine did the same thing, dealer replaced under warranty no questions asked.
Old 09-30-2008, 03:04 PM
dawg's Avatar
dawg
dawg is offline
Received 3,246 Likes on 1,852 Posts
Every scoot comes with a 2year factory warranty beginning from the date of purchase. This is covered under warranty. Make the dealer replace your cover and gasket.
Old 09-30-2008, 03:13 PM
Mr. Clean's Avatar
Mr. Clean
Mr. Clean is offline
Had it happen on my front master cylinder on my old Heritage. Cleaned off the bubbled paint and lightly sanded the area. Washed the affected area with a cloth soaked in solvent. Masked of the area around the master cylinder and covered the rest of the bike. Sprayed red primer on the exposed area and then sprayed on satin black paint.
The end result was pretty good. Sorry, no pics, but make sure the master cylinder cover is on snugly and both screws are tightened evenly or it will happen again.
Also, if you plan on removing the master cylinder cover, make sure the handlebars are turned to the left so that the top of the master cylinder cover is as level as possible. Cover any ares below the master cylinder that might get dripped on if any brake fluid leaks out when you remove the cover.
Brake fluid is one of the best paint removers - especially when it gets on something you do not want to remove the paint from.
Old 09-30-2008, 03:16 PM
jarhead45's Avatar
jarhead45
jarhead45 is offline
sand and repaint ... I need to also
TomWoodgeard's Avatar
TomWoodgeard
TomWoodgeard is offline
My dealer told me it's very common on the 07's. Replaced the entire assy under warranty.
There was an issue with a vendor on the flatness of the m/c cover. Tried to get them to put on a chrome m/c cover since they are the same price as the black ones. No go.....
Old 09-30-2008, 03:32 PM
I am Jerry's Avatar
I am Jerry
I am Jerry is offline
My '06 was leaking, I didn't figure they would put the chrome one on so I just bought one myself and it fixed it. Luckily I caught it before it did any damage.
Old 09-30-2008, 04:51 PM
powdercoater's Avatar
powdercoater
powdercoater is offline
I've been powder coating for about 10 years and do a LOT of master cylinders. Never had a problem including the ones on mine and my wife's bikes that have been done for years. Get them powder coated and be done with the problems.
Old 09-30-2008, 06:04 PM
robzuc97's Avatar
robzuc97
robzuc97 is offline
That's DOT 4 for ya!
Old 09-30-2008, 07:30 PM
hogdvr's Avatar
hogdvr
hogdvr is offline
It's covered under warranty.
Quick Reply: Master Cylinder and Bubbled Paint
