shift rod lubing
What and How do you all of you out there do and use to lube the shift rod in the inner primary case? Mine is starting to squeek alittle when I shift. The rod wont come out without removing the inner primary, and it will only slide back a little ways. The moco doesn't put a grease nipple on the case anymore. Let me know what you guys do.
Thanks
Thanks
I've had this up for some time. Further down the thread I've listed all the necessary parts, drill bit, tap, zerk fitting and what you have to do to install it.
Enjoy
