2009 Ultra antennas
Old 09-28-2008 | 07:16 PM
shy1's Avatar
shy1
Default 2009 Ultra antennas
I found for storage, the two antennas can be removed and stored in the tour pack. One antenna is labeled CB, the other is unlabeled. Now the problem. Both posts on to which they are attached on the tour pack are identical. Which side of the tour pack is the CB antenna attached, and which side of the tour pack is the radio antenna attached?
Old 09-28-2008 | 07:27 PM
dawg's Avatar
dawg
Left side AM/FM
Right side CB
Old 09-28-2008 | 07:31 PM
IRready's Avatar
IRready
Originally Posted by dawg
Left side AM/FM
Right side CB
OK, silly question..... left as your sitting on the bike or left as you looking at it? I only ask as I have removed mine and have no idea if I replaced correctly. AM/FM works fine though. Never used the CB.
Old 09-28-2008 | 07:35 PM
dawg's Avatar
dawg
left as you're sitting on it and if you're looking at the tourpak from the rear it would also be left.
Old 09-28-2008 | 10:38 PM
wilson's Avatar
wilson
2nd Gear
may be a dumb question but - what happens if you mix the antenna up and put the am/fm on the cb post and the cb antenna on the am/fm post?
Old 09-29-2008 | 05:23 AM
jkoch09ultra's Avatar
jkoch09ultra
They will receive with some loss of reception. I know dealer put mine on backward on my 06 UC. You will damage your CB if you transmit with the AM/FM antenna on the right side.
Old 02-09-2009 | 09:49 PM
shy1's Avatar
shy1
Left side AM/FM
Right side CB
Thanks for the response. Sorry I'm so late in expressing my appreciation.
Old 02-09-2009 | 10:14 PM
cap5369's Avatar
cap5369
That is correct CB is on the Throtal side and AM\FM Clutch side.
Old 02-09-2009 | 10:17 PM
Lawdawg's Avatar
Lawdawg
You can also tuck the ends under the back rest...I don't know if prolonged storage would damage them though.
Old 02-09-2009 | 11:08 PM
Concrete Cowboy 2009's Avatar
For further gearheading, and if I'm not mistaking, you can check the wires... The big one is the CB Coax. and the small one is the AM/FM. These guys are right tho.
Quick Reply: 2009 Ultra antennas
