Fuel Guage
Old 09-28-2008 | 01:44 PM
banks727's Avatar
banks727
Default Fuel Guage
I have an FLHR and I'm having problems with my fuel guage. Hard as I try when filling it up, the guage never reads full. It always reads well low of actuall. For instance, yesterday I filled up showing about 1/8th tank and put in under 3 gallons. I know I can just look at the miles and guestimate, but should I have to do that on a new bike?
I called the dealership and they said they would look at it. Has anyone else had this problem on their Road King or similar?
Any thoughts?
Banks
Old 09-28-2008 | 01:51 PM
RoadKing_Al's Avatar
RoadKing_Al
What are you worrying about? Let the dealer straighten it out.
Old 09-28-2008 | 01:53 PM
OneBlackFly's Avatar
OneBlackFly
There are two possible problems with your gauge., One, the sender unit is bad, or two, the float arm needs to be adjusted. H-D gauge are notoriously bad, but mine finally works well after the dealer installed a new sender unit and adjusted the float arm. I still use the odometer as a cross check for when I need to get gas.
Old 09-28-2008 | 01:56 PM
Bluesssman's Avatar
Bluesssman
I have to agree, let the dealership worry about the problem, not you. Just get on and ride!!!
Old 09-28-2008 | 02:31 PM
harley-jones's Avatar
harley-jones
When my gauge reads empty I can only squeeze in about 4 gallons in my 6 gallon tank.
I guess the beauty is I should never run out of gas if I just fill up when it shows empty.
Old 09-28-2008 | 02:39 PM
MeanMorningJoe's Avatar
MeanMorningJoe
I always use the guage as an indication... I go by miles and reset the trip odomiter at each fill up. Never liked the guage set up at all. I swapped out the ambient temp guage for an oil temp guage. Figured that was a little more useful.
Neil
06-09-2013 09:29 PM
liltrk
08-26-2007 08:17 AM
OscarsSoftail
05-29-2007 11:07 PM
daveyclyde
Exhaust System Topics
04-30-2007 09:29 AM
dhutchison
07-15-2006 01:57 AM
Quick Reply: Fuel Guage
