Oil changes Tranny and Primary?
Old 09-28-2008 | 06:03 AM
jcbpa's Avatar
jcbpa
Default Oil changes Tranny and Primary?
How often? Please don't tell me when dirty
Old 09-28-2008 | 06:08 AM
crash1292's Avatar
crash1292
I do the engine .....I do them all
Old 09-28-2008 | 06:55 AM
jcbpa's Avatar
jcbpa
wow... did not think it was needed that often. What do you use?
Old 09-28-2008 | 06:59 AM
mjmangus's Avatar
mjmangus
I do all 3 holes in the spring and in the fall or every 3k-5k miles. I use amzoil.
Old 09-28-2008 | 07:07 AM
jcbpa's Avatar
jcbpa
which Amsoil for the tranny and primary?
Old 09-28-2008 | 07:12 AM
LH's Avatar
LH
Every 5000 miles. Amsoil 20-50 engine ... Redline HD shock trans .. B&M auto fluid (non-syn in the black bottle). You can't beat that combo, you might match it but you woun't beat it.
Old 09-28-2008 | 07:13 AM
mtairy biker's Avatar
mtairy biker
I use amsoil 20-50 in the primary and change it with the motor at 5k
In the trans i use amsoil 75-90 and change it every 10k
Old 09-28-2008 | 08:27 AM
Skivvy9r's Avatar
Skivvy9r
Primary 10K mile interval, transmission 20K mile interval. Or every 24 months if you don't ride much.
Old 09-28-2008 | 09:06 AM
cruise_carter's Avatar
cruise_carter
primary and transmission intervals are not as frequent as the engine, but it's easy to do and only takes a little bit more time.
I change primary and transmission when I change the engine oil
Old 09-28-2008 | 09:12 AM
skykingFLHTCU's Avatar
skykingFLHTCU
All three at about 3000 miles. Maybe overkill ut oil is cheap compared to engines and trans. All with Syn 3
Quick Reply: Oil changes Tranny and Primary?
