V&H ovals on 09 flhrc
Old 09-27-2008, 08:17 AM
bpav16's Avatar
bpav16
bpav16 is offline
Default V&H ovals on 09 flhrc
I got some used ovals for my Road King Classic...all seemed ok but when I contacted V&H about fuelpak maps, they told me they had none because they didn't have ovals for the 09 touring line. Claimed the pipes were too close to the axle nut. Well I took them off and put the stockers back on and to my eye, the distance to the nut looked the same...Any thoughts please.
Old 09-27-2008, 08:23 AM
RODEO's Avatar
RODEO
RODEO is offline
Seeing is believing. If you eyeball them to be the same distance, what is the problem?
Old 09-27-2008, 08:35 AM
Deepsouth251's Avatar
Deepsouth251
Deepsouth251 is offline
Go to the V&H web site and check the list of available pipes for 09's other than monster ovals and radius and maybe 1 or 2 more, there are none which also means there is no map for them. There's also no Power Commander available for 09 touring yet. Just seems to be something we have to live with for a few weeks. Spoke to V&H on phone could not get a date for available but I did ask week or months, he said weeks.
Old 09-27-2008, 10:51 AM
r8rs4lf's Avatar
r8rs4lf
r8rs4lf is offline
There is a map available for the '09 monster ovals. I looked it up. My set of '09 monster ovals are on order and are supposed to be shipped on the 25th of this month.
Old 09-27-2008, 11:09 AM
RK Ivan's Avatar
RK Ivan
RK Ivan is offline
Default idea
Do you have Stage 1?? If so it is not that far off from stock touring mufflers w/stage 1. Just put a pair on my buddies EG w/stage 1 tweaked his PC III a little no problems. Axle nut may be different cuz tries on '09's are wider (180?) but Saturday Night Special is right, seeing is believing
Buzz
Old 09-27-2008, 11:27 AM
flyingace's Avatar
flyingace
flyingace is offline
Lift your bike up on a jack, and make sure that with the rear shocks fully extended (wheel off the ground) that the axle nut does not hit the pipes.
This is the reason they had to re-design the heat shield for the monster ovals for 09 bikes.
Old 09-27-2008, 02:06 PM
bpav16's Avatar
bpav16
bpav16 is offline
I did get her on the lift and it did clear the pipe....I'm gonna run with these....thanks all
boready2
11-11-2013 05:41 PM
karjar
Exhaust System Topics
12-09-2010 09:06 PM
Maldetete
04-23-2010 04:01 PM
fettnersa
09-27-2008 07:21 AM
r8rs4lf
09-17-2008 02:18 PM
Quick Reply: V&H ovals on 09 flhrc
