Re-Torque Fairing Screws
I wouldn't use Loctite on anything that's near a plastic part, as it may cause it to crack in the vicinity of the application. This is a known problem and you can read more about it on the Loctite FAQ, but I'm not sure if the type of plastic used on HD fairings is subject to the problem. I do know that HD recommended using Loctite on the quick-disconnect kit for the fairing lowers, which I think is the same type of plastic as the fairing, so perhaps it is okay to do. I still wouldn't use it there, however--and keep in mind the top screws are also near the windshield, which is another type of plastic.
I had a discussion about this with a Loctite sales rep and he said the problem was the "light ends" (carrier liquid) in the solution, and once it evaporates there is no risk. The problem for most applications is keeping it away till that happens.
Protection
