Re-Torque Fairing Screws
Hey kjmorgan...
It's a piece of cake! I did the same thing several weeks ago. Speaker upgrade, Kisan modulator, HD XM unit, new painted inner fairing, oil temp gauge...it looks great and sounds a whole lot better!
BTW...while you have the fairing off put some DynaMat on the inside of the front half of the fairing to reduce resonance! It makes a big difference!
Steve
Steve
Great advice
I use the blue loctite at work and it is great stuff. I have also used the purple loctite for real small screws and think it may hold good for this application and break loose even easier. Just a thought here. I haven't lost any of without using any thing so I never would have thought of this. Thanks much Guy's.
I had my fairing cap off to replace my handlebars. I did not use locktite,nor did I torque the screws. I have yet to loose any of them,and I do get alot off viberation. I have been a mechanic for over 15yrs. and I was always taught not to use locktite on plastic. Are you guys sure it won't damage the plastic?
Purple loctite
For the fairing screws, Permatex Purple works great!
http://www.permatex.com/products/mot...ker_PURPLE.htm
+1 Purple loctite
Could be that the fairing just settled in a little. I don't think the screws moved. It is not like torquing to metal parts together. I usually retighten after the first ride.
I use blue Loctite after I clean out the bolt holes with a pipe cleaner & compressed air. Although I am a firm believer in torque wrenches I think they provide to much lateral stress when used with delicate plastic parts. I use my very smallest socket wrench and torque by feel.
