Adding cb/intercom to my road glide
I am about to pull the pin and order tour pak, cb and intercom for my '07 RG. A couple of questions for those that have done this. Is the switch kit PN-77173-07 required for the '07 road glide? When the book says an "Intercom system flash" is required, is this a download plug in from the dealer? Not sure what they mean by the above and is listed as PN-76441-06/DT. Also, I could not find CB pod trim badge in catalog. What is this. Any help would be appreciated.
Thanks
Thanks
There is another thread on this subject. That thread died because nobody posted. I want to do the same thing but there seems to be very few people who have done it.
My question is this . . .
Why would I need to buy the LH switch pod and speaker switch when I already have them. All I should need is the console and wiring.
Also, what would it take to add the passenger plug for the intercom?
Steve
Steve
You don't need the squealtch/PTT buttons, they are there. You will need the radion flashed to recognize the CB after you install it. You will need the wire harness that goes between the radio and the rear of the tank(most expensive piece at @$300 aside from the CB module that you can make if you have access to a Deutch crimper ). You will need the CB console, plug and weather cap, the antenna, coil and wire. And the headset
Thanks,
Steve
Im the one that did a thread on this a few days ago, here it is if you want to read the research I did so far:
https://www.hdforums.com/forum/touring-models/278531-road-glide-ultra-help.html
I never knew you had to have cb for intercom to work, P & A book doesnt mention it. I still dont understand the difference between buying the "advanced audio system wiring harness " they mention in book and "ultra audio overlay" thats listed in parts manual.
I really just wan the rear speakers and intercom for long trips with lady, but would add CB if I need to. I just dont know which way to go just yet.
https://www.hdforums.com/forum/showthread.php?t=278531
BTW, I love your lowers. Why the HELL do you have to buy the boxes separately???? All the other lowers come with them.
