07 0wners ?????
#102
#103
GUMBY - Inquiry about the IDS . . .
Independent Drive System. Search the forum under IDS and you will see numerous posts. It was installed after 07 to quiet the 5th gear transmission noise. The 07 owners have to purchase the part. MOCO did not issue a recall nor is it covered as a warranty item.
#104
#105
At around 10,000 mi. had a fairing bracket failure. Replaced under warranty. Also had the HK stereo develop a seal failure. It was also replaced under warranty with a new unit. At around 10,005 mi. had a saddlebag spring break. Replaced under warranty. Next, had some funky vibrations. Turned out to be the tires cupping. Also had the rear brake rotor warped. All but the tires replaced under warranty. Now, about 8,000 mi. later, I have a broken saddlebag spring again and the ambient temp gauge bulb is out. Will get saddlebag spring replaced under warranty and replacing ambient temp gauge replaced with an oil temp gauge. Also, looks like I have another HK stereo seal failure so I'm going to be getting it replaced again as well.
This is my primary transportation so I ride year round. Riding and repairing...guess that's going to be my life till I get an 2012 Street Glide. I'm going to force myself...actually, the economy is forcing me...to hold on to my beast for at least 5 years. I'm looking forward to buying my next bike with cash! ...ok, I might need to hold on to it a little longer if the markets refuse to come around before my prime stock are reduced to ashes from the fire I must burn to keep warm.
#106
#107
#110
I really like my 07. After riding a 1986 glide - it's a huge improvement. Only discomforting thing was engine heat and tour pack location. Installed RJS origionals, XIED's and a George Anderson set back for the tour pack and all is fine.
Never purchased any motor vehicle that didn't require some "home re-engineering" :-)
