What air pressure in rear shocks?
I picked up my new FLHTC in June 08 and rode it for 2 months then checked the rear air shocks to see the PSI and nothing! This is after the 1600 km first check up. Did the Dealer Tech miss checking this? I used my friends shock air pump and put 18 lbs in it. and it holds OK.
I thought they would have checked this and I should have also I suppose. What PSI does everyone set theirs to. I'm 250 lbs and occasionally ride with a passenger so I'm running around 18 PSI and it seems very smooth.
I read the manual and saw the chart. It doesn't look like there is any damage but I couldn't believe there was no reading at all. My friend (with the pump) said he picked his new Street Glide up and had 3 PSI in his shock.
I am about your size. My wife is about 1/2 that.... We are still looking for that psi that gives us the ride we are after.... 20 was not enough for two up, and she is thinking 30 is too stiff. Gonna try 25 next time 2 up. Running solo, I like 20 psi.... gives me the ride I want. Good luck!
I honestly think each bike is different, and that you've really got to just play with it until you get it where you want it. Try a log book, and record the setting (psi) and then as soon as you return from your ride record your impressions. Then make your adjustments, and do the same thing. After about 4-5 adjustments, you can dial that baby in, and you know what's best for both solo, and two-up riding....
