Keeping It Charged
Old 09-22-2008 | 09:30 AM
ajpuck's Avatar
ajpuck
Red face Keeping It Charged
I had done a ride to Virginia Beach and when I got home I tried to connect a battery tender to my bike because I was going to let it sit for a while. When I connected my battery tender trickle charger to the pigtail on my '08 Electra Glide Classic the light on the charger started flashing red. According to the charger this means that it isn't charging. I switched battery tenders and the new one did the same thing. It worked before the trip. Unfortunately I am not very good at wrenching. Any suggestions for me to try? Thanks!!
Old 09-22-2008 | 09:50 AM
Skulmn's Avatar
Skulmn
check the leads to the battery. If they are still connected check the fuse on the + lead.
If you've tried a second battery tender, it has to be that one of the leads to the battery for the fuse has gone bad.
All connections should be easy to see under the seat.
Old 09-22-2008 | 10:34 AM
LH's Avatar
LH
Make sure you connect the Tender to the battery first BEFORE you plug it into the wall. It has to sense some current from your battery first before it will charge.
Old 09-22-2008 | 11:04 AM
gunner11's Avatar
gunner11
Just ride it everyday, no worries!
Old 09-22-2008 | 11:10 AM
Chula's Avatar
Chula
Connections
jazzar35
05-07-2023 09:13 PM
cgmartine
Electrical/Lighting/Alarm
19
11-11-2020 10:56 PM
ElectraJim
07-12-2018 02:43 PM
chipguy1
09-03-2013 06:18 AM
falsealarm
11-21-2007 03:22 AM
Quick Reply: Keeping It Charged
