Ignition Fuse
You have a short somewhere as I'm sure you know this. Not sure how to tell you to try and find/trace it? But that is not normal. I'd start at the right side handle bar switch housing and go from there. A friend I work with bought a brand new 06 EGC and with les than 500 miles hit a pot hole and the bike shut off. Had it towed back to the dealer and one of the ignition wires was pinched under the right side switch housing and when he hit the pot hole it shorted out on the handle bar. HTH and good luck.
Also,It mainly happens when I'm getting down on the throttle,Or cruising at a higher RPM..
BaggerBill103
Electrical/Lighting/Alarm
08-19-2018 07:23 AM
crawfordcl
09-15-2010 10:52 AM
