My speaker upgrade (DUW)
Hey y'all.
One of the things I wanted when I bought the new SG was to add the lowers and a four-speaker HogTunes setup. I got that done this week. I first applied DynaMat (you can get it at Best Buy) to the inside of the fairing and to the inside of the lower glove boxes. The speaker upgrade was easy, the instructions were good and the entire job, including DynaMat, took about 3 1/2 hours as I took my time. This setup rocks! The sound has so much depth and texture and I even had to turn the bass down to about 5-6 bars. That is with a lot of wind noise from that short little air deflector that comes stock. It should be even better when my Clearview windshield comes in.
Take a look:
Speakers installed in fairing and amp for lower speakers velcroed to radio:
DynaMat applied to the main fairing:
Speaker mounting bracket for lower fairing, DynaMat visible:
Shot of lower speaker:
View of inner fairing with new speaker bezels:
Shot of lower speaker with grill cloth attached:
Thanks for looking.
Take a look:
Thanks for looking.
The DynaMat helps turn the fairing into an acoustical chamber and helps with bass response. If you want an example, pop your fairing off and listen to your stereo - no depth, no bass, not texture. Putting your fairing back on brings that back out. The comparison between a plain fairing and one with DynaMat is similar to that. It is not a miracle worker, but it really helps.
The amp powers the lower fairing speakers only. The radio powers the uppers. If you are just going with the batwing, I don't think you need an amp and you will probably be surprised with the increase just the upgraded speakers provide.
