My speaker upgrade (DUW)
Old 09-20-2008, 10:01 PM
Glyde's Avatar
Glyde
Glyde is offline
My buddy just did the hog tunes 6 speaker kit on his Ultra and it's unreal. I'm ordering the lowers shortly, will very likely do the same setup as you. Thanks for sharing.
Old 09-21-2008, 12:56 AM
Bobberino's Avatar
Bobberino
Bobberino is offline
Weird thing bluzmn59 is I did the dynamat aroundmy6x9's in my bag I didnt think of my fairing.....HHHMMMM......
Old 09-21-2008, 06:06 AM
WillieC's Avatar
WillieC
WillieC is offline
Thumbs up Great Job
Thanks for the great report and pictures, well done !
Old 09-21-2008, 06:45 AM
masterblaster's Avatar
masterblaster
masterblaster is offline
This is an expensive place to look. Thanks for the report.
Originally Posted by kjmorgan
Thank you, thank you, thank you! I learn something every time I check in here!
Old 09-21-2008, 08:06 AM
Bluzmn59's Avatar
Bluzmn59
Bluzmn59 is offline
Originally Posted by caspr2
Nice looking setup, I've been thinking about adding speakers to my lowers and putting quick disconnects on them as they always come off in the summer.
They are already set up that way. If you look at the picture of the lower speaker without the grille cloth, you can see the plastic clip behind it to the left. The main speaker wire comes out of the bottom of the fairing and ends with two clips that go to the separate speaker wires that run along the engine guard in either direction. You can disconnect them just tuck the main wire back up inside the fairing. The only issue you will have is that you have to remove the speakers from the mounting brackets to get at the bolts that hold the upper part of the lower fairing in place. I have never looked into it, but maybe the detachable hardware from Harley would fix that issue. Of course, with detachable hardware, you would then be asking someone to steal your lowers and speakers.
Old 09-21-2008, 08:40 AM
Lightngsvt2's Avatar
Lightngsvt2
Lightngsvt2 is offline
Nice job! Kind of off topic, but does having the lowers on make the bike noisier overall (increased drive train noise, etc)?
Old 09-21-2008, 09:15 AM
acchd's Avatar
acchd
acchd is offline
Nice job brotha! BTW you can get a 4 sq ft sheet of Dynamat Extreme for ~$24 shipped on ebay and save a litte dough.
Old 09-21-2008, 10:15 AM
LucklessPedestrian's Avatar
LucklessPedestrian
LucklessPedestrian is offline
Nice work!
Old 09-21-2008, 12:15 PM
Bluzmn59's Avatar
Bluzmn59
Bluzmn59 is offline
Not that I have ever noticed.
Old 09-21-2008, 12:30 PM
spizzyman's Avatar
spizzyman
spizzyman is offline
Thanks a lot. :-( Now there is something else I can't live without. Time to spend more $$$. You did a great job with the pics. How much is the Dynamat? Did you say or did I miss it? Does the new set up add volume or just clean it up and add bass?
spiz
Quick Reply: My speaker upgrade (DUW)
