Replacing handlebars on my 08 RK
Old 09-20-2008 | 05:27 AM
Sketz's Avatar
Sketz
Question Replacing handlebars on my 08 RK
I'm about to replace my stock handlebars with the new Heritage style bars as a lot of folks on this forum did. However, I noticed on some of the threads that there were a few who had problems with the "fly-by-wire" throttle sensor not working after the change.
Are there suggestions/tips that I should do as to not create this problem when removing/installing the new bars?
Thanks for any input.
Old 09-20-2008 | 06:32 AM
patsfan's Avatar
patsfan
If you plan on running your switch wires internally, it will be very tight. I think thats where most have had issues when pulling wires thru and damaging the sensor. If not, you shoouldnt have any problem.
Old 09-20-2008 | 07:39 AM
joker1450's Avatar
joker1450
if you want to put internally the wires, the only solution in order to prevent the damege of the wires is to use a "borotalco".
Old 09-20-2008 | 07:53 AM
Sketz's Avatar
Sketz
Exclamation
I don't plan on putting the wires into the handle bars - I'm just concerned about taking the throttle grip off/on the old and new bars and damaging the sensor - is there a trick to do this, as I mentioned before, some people have had trouble doing this which resulted in a damaged sensor.
Old 09-20-2008 | 08:16 AM
Big Pa's Avatar
Big Pa
I had 16" ape hangers put on my '08 RK. I don't know the brand of bars they ordered, but they came with the notched right hand side made for the throttle by wire system. The wires were internal. The brake & clutch cable (braided), had to be special ordered because of the length.Turns out I hated the apes! Had a indy shop put the stock bars back on. No problems there either. The stock bars aren't internaly wired, but the fly by wire unit went back in without any problem.(A couple of times!)
Joe
P.S. The 16" apes & whole
setup is 4-sale.
Old 09-20-2008 | 09:12 AM
Jinks's Avatar
Jinks
Shouldn't be a problem. Just feed wire into the handlebars from the wire harness to allow enough slack to get the sensor out of the bars. Don't "yank" on the sensor. When the connector comes out of the bars you can disconnect the sensor & set it aside till you get the new bars on & the sensor leads threaded through 'em. Then plug the sensor back in, feed the harness back in & button it up. You only need to be gentle with the harness wiring for the sensor. The twist grip comes off like all the older ones, but you'll find that the stock grip is notched to fit the gear on the end of the sensor so you're stuck with stock grips until someone comes out with aftermarket grips for the TBW.
Ahooosier
2014-2023 Touring Models
15
07-31-2015 04:58 AM
scuba1954
03-10-2010 06:27 PM
santajim
04-14-2009 11:01 AM
Blkprl44
04-26-2008 07:53 PM
stang9986
01-21-2008 09:29 PM
Quick Reply: Replacing handlebars on my 08 RK
