21" wheel on stock fender?
09-19-2008, 06:05 PM
Just wanted to make sure my 21" wheel will fit under my stock fender. Its a 21X3. Got my rotors and tire today and no wheel
Maybe tomorrow!!
09-19-2008, 06:09 PM
I had to "drill out" the rear mounting holes. Do a search, this question has been asked no less than 500 times.
09-19-2008, 09:53 PM
ya make sure u "rock" the fender forward or it will rub slightly on the backside of your fender, and it could bubble your paint...
09-20-2008, 07:34 AM
Had the dealer put a 21" on my 09 street glide at pick up and it fits just fine.
09-20-2008, 08:17 AM
at High Speeds it may hit in the Back so open up the rear holes a little and lift the rear of the fender
09-20-2008, 03:25 PM
i had to drill mine
08 street glide 21 x 3.50
09-20-2008, 03:43 PM
09-20-2008, 04:50 PM
Alot depends on the rubber you be running,most that run a 21 incher need to rotate the fender slightly as described above.Tape a 3/8th width nut around wheel at tires highest point,give it a spin.Mine touched only slightly yet elongated fender until no rub was heard.Like others have said some tires grow as speed/temps increase,why waste a good paint job?
09-20-2008, 08:33 PM
Thanks for all the help fellas. I thought for sure it would have been here today. Everytime I saw the brown truck... I knew it was gonna be for me. How much did the dealer charge you for the install crp5?
No U Glider
2014-2023 Touring Models
08-25-2017 06:56 AM
Lunchboxx
03-04-2016 03:47 PM
Beach Bagger
10-29-2010 11:11 AM
flight
08-30-2010 12:07 PM
Rocket Man
01-20-2008 03:15 PM
