I am wondering what air pressure folks are running in their ultra's. I am running around 10 pounds when I be solo (225 pounds) and 25 pounds with the passenger.
300lbs for me and always solo. Mine leak some so I put in 30lbs. every 3-4 weeks. I can tell when they leak down too much when the bike starts to wag a bit in a turn.
One other time this discussion came up and I wrote down the numbers people gave. I then took the average of all the numbers which were as follows: 1 up = 12 psi 2 = up 17 psi.
This gave me a good starting point. I now use 1 up = 13 psi and 2 up 19 psi. BTW if your shocks bleed off then there is a problem with the shock system (hoses, shocks, or air valve!)
