Rush True Duals
I have the Rush headers and the mufflers. I'd be hard-pressed to understand how Rush TDs could be appreciably different than any other TD header (say, V&H) in the noise department. Um, I mean the bends and diameters are almost exactly the same, right? As for the ceramic coating reducing heat: Does Rush claim that they do? I'm not a a thermodynamics engineer, but again I'd be hard-pressed to see how it would make a noticeable difference. Overall, the combo sounds fantastic with 2" baffles. I don't know what "too loud" means. Are they louder than stock? Yes. Are they quieter than straight pipes? Yes. I like them. And they have very nice chroming. I am told that Rush uses the same chromers that HD uses for many of its parts.
Thanks for the input guys. What I meant by too loud, is on my 01 RKC I had a set of Samson true duals with their oval pipes, great sounding except when going down the highway at 70-75 mph it was loud. The guys in the group riding with me wanted me in the back. As for the ceramic coating you don't see it anyway with the heat sheilds on.
I have this set up. Very happy with sound and the heat reduction. I have removed the rear heat shield to adjust pipe and coating looked new no blueing at all. Not real happy with the way the rear pipe support bracket is so close to oxygen sensor. Spent a lot of time trying to get it further away from sensor. Not hitting it but just too close for my likings. Not sure if the ceramic coating would be noticeable without it? Ceramic coating is inside also thought exhaust might flow smoother? I had Samson mufflers on 02 and the Rush mufflers are not near as loud.
