Floor Board Mounting Brackets
I've had my '03 RKC for a few years. Over this time I've been grinding the floor board brackets and floor boards cornering. Couple weeks ago using on-ramp, right sweep, the bike actually came to rest on bracket and started to slide across road surface. HOO-YAH, there's an attention grabber.
Anyone know of an after market mount that provides more clearance?
I know, already been told I have the wrong bike but I'm not getting rid of it. No rice rockets here!
I know that there are brackets to move floorboards forward and other ones to move them out an inch- no thanks on moving them out, that will make it worse.
Thanks for any suggestions.
I wondered about exceeding the tires capabilities. I took a good look at front tire and "whiskers" are still. It actually looks like there is a fair amount of tire out from center that isn't being used up to this point.
As to forward controls it is doable. There is another thread under "no floorboards" I found tonite w/ pics showing it. However, it appears you can't have crash bar mounted and I won't do that.
I may have to remove brackets and grind some material off but will still end up grinding the outside edge of floorboards. It's already happening. I'll talk to the speed shop does my work to see if he has capability of fabing some new ones for me.
There is atleast one company that allows you to keep your crashbar while using forward controls. J-Brake I believe is the company. Have you tried moving your boards to the upper position yet. If you look where they mount, you will see different mounting holes. Granted, the one on the right side is a MAJOR pain in the *** to get to, but I did mine and it makes a considerable difference. We just got back from the dragons tail where I always drag my boards and brakets. This trip, however, I didnt. I did get into my pipes, but not the boards. Just something else to look at. Hope it helps.
