True Duals-thoughts
It comes down to a few issues I think:
Finish - V&H and Rinehart
Sound - Personal preference, most sound great.
Performance - Most tuners will get more power out of Rineharts.
Versatility - If you are one of those mess with all your stuff kinda guys, like changing mufflers a lot down the road. Then not Rineharts or any other 2" pipe. Not that many options with 2" pipes.
The real difference in power is nominal. A few ponies here and there is all.
Just my opinion,
U
Just my opinion,
U
I've had Rinehart TD's with chrome end caps for 3 years and haven't seen or heard anything better FOR ME. If I was buying now, I'd look hard at the Bub 7 without the crossover. The V&H are popular and an excellent product.
For my riding, I don't get the "loss of low-end torque" issue that is always raised with TD's. In suburban traffic, I don't acclerate hard from a traffic light because of traffic or I'm not in a hurry, and when riding twistys I'm usually turning 2500 to 3500 rpms and using gear selection to slow the bike. And cruising interstates on long trips is a non-issue. I'm not knocking those who prefer 2-1 pipes or the actual minor loss of some torqe in a narrow rpm range. Just saying I'm really pleased with the Rinehart TD's.
Good luck with your research.
Im at the same point you are shopping for duals. My bike came with screaming eagle 2:1 and although the performance is fine I dont like the look and sound....I know for sure Im getting something black ceramic coated not only for the looks but also to reduce heat some. The D&D fat cats 2:1 are high on my list not only for the fact that they are 3-400 dollars less than some of the dual set ups out there and will give great performance and looks...
One issue ive been wondering about with these klock werks headers is how is the added heat being held around the cylinders going to affect the engines in the long run? Not only is the header wrapped around the cylinder radiating tons of heat back onto the base of the cylinders but also the header is blocking off cooling fins reducing the heat dissipation as well......maybe klock knows something I dont but I dont see them being very beneficial other than a new look
