Will 07-08 exhaust fit my 06?
Old 09-16-2008, 06:47 AM
steveh326's Avatar
steveh326
steveh326 is offline
Default Will 07-08 exhaust fit my 06?
is the only difference in the 07-08 exhaust systems the O2 sensor bungs? If I got a system made for an 07-08 and I plugged the bungs, would it bolt up to my 06?
Old 09-16-2008, 08:01 AM
IM744's Avatar
IM744
IM744 is offline
I dont think that it will. The 06's engine is smaller and I dont think that the exterior dimensions are exactly the same. This will cause probs
Old 09-16-2008, 01:12 PM
Sincecrazy's Avatar
Sincecrazy
Sincecrazy is offline
I think that it would probably work. The best I know the difference is internal, not external as to a size comparison between those year models.
Old 09-16-2008, 06:31 PM
jag1886's Avatar
jag1886
jag1886 is offline
Yes it is the same. You just have to plug the O2 sensor holes.
Old 09-16-2008, 07:29 PM
Chula's Avatar
Chula
Chula is offline
Why would you want 07 or 08 exhaust? Is there any benefit?
Old 09-16-2008, 09:49 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
I don't know if the entire system will fit, but the mufflers sure will. I installed a set from a 2007 Street Glide on my 2003 Ultra. The bike now runs and sounds much better due to less restriction.
Old 09-16-2008, 10:23 PM
shawn calvin's Avatar
shawn calvin
shawn calvin is offline
i just put a 07 street glide exhaust on a 02 electra glide. it fits the exact same as the old exhaust, just get some o2 plugs from reinhart.
Old 09-17-2008, 12:23 AM
rdkingryder69's Avatar
rdkingryder69
rdkingryder69 is offline
It will fit
Old 09-17-2008, 03:40 PM
FLHXn's Avatar
FLHXn
FLHXn is offline
I called Vance and Hines for this exact reason. The six speed trans is a little larger and the bends around the trans are slightly different. He said that it may still fit, but the bends are different to accomodate the trans.
Old 09-17-2008, 04:04 PM
leohd's Avatar
leohd
leohd is offline
the trans brackets are different on a lot of pipes
Quick Reply: Will 07-08 exhaust fit my 06?
