IDS/cush drive 08>07 ????
09-15-2008, 10:14 PM
Will a IDS/cush drive, pulley from and 08 touring bike fit on my 07 road Glide?
thanks,,,,
09-16-2008, 05:05 AM
As far as I can tell it will. It is listed in the catalog as an accessory.
09-16-2008, 07:11 AM
Not positive, but I think the axle size is different on the 08s.
09-16-2008, 07:15 AM
It will not fit. The axle OD forthe 2007 is 1.00". In 2008 they went to a 25mm shaft OD to accommadate ABS. I think all you have to do is use the bearing for a 2007. They cost about $22.00.
09-16-2008, 07:45 AM
doesn't the kit come with the replacement bearing?
09-16-2008, 02:01 PM
Quote:
Originally Posted by
huffhuff
Yes, it does but "raw" isn't using the kit.
09-16-2008, 06:22 PM
You need two spacers and a bearing to make it work
11846 spacer
11844 spacer
40670-06 bearing
I have an 08 IDS on my 07.
09-16-2008, 10:08 PM
jag1886
11846 spacer
11844 spacer
40670-06 bearing
Jag ,thanks for those part numbers.
What was the rough cost for all of those pieces?
09-17-2008, 12:24 AM
retail prices:
11846 $31.76
11844 $5.85
40670-06 $22.35
09-17-2008, 11:07 AM
jag1886 is right on I got my ids pulley off an 08 that was getting a trike conversion those were the exact part numbers i used one bearing and two spacers
