Pawl adjustment ?
Pawl adjustment ?
Started having shifting issues appx 300 miles back, adj clutch yesterday, no help. Read about pawl adj., found pawl adj screw lock nut loose, in 3rd gear had appx 1"+ movement forward and spring back, but no back movement. Started turning adj screw forward and statrted to shorten up forward and corresponding spring back. Got to the point where I had a little back wards movement and corresponding spring back, turned screw just a little in the opposite direction and now shifter lever has neither forward or backwards movement, is this good, manual doesn't specify how much movement. Thanks
