I had the local shop put on a new screamin eagle flatside 45 carb. in order to install it they had to file 2 fins on the jugs down, which they did, but its now knocking. not badly, but audible, and coming directly from the carb. I've taken a close look, and the carb doesnt seem to be hitting anything. they claim that its a normal noise for that carb... I wanted to consult you folks before raising S#!*.
what does your build consist of cams,compression,cubic inches, etc??
Yes the slide will make noise for sure, but also check to see if the **** on the idle cable isn't tapping on the rear jug.
You were right, i pulled the air cleaner off and pushed on the slide, sound went away. i'd ruled the slide out right from the start because its more of a knock than the rattle i would expect from the slide. once again you boys saved me from walking into the shop and making an a$$ of myself. well done.
