Mobli 1 oil?
G2156 - A Study of Motorcycle Oils
A fairly easy to read study - don't know who wrote it, but it substantiates another study that directed me to Mobil 1 "V-Twin" in the first place. One of the factors especially in a air cooled v-twin is the amount of Zinc (ZDP) the oil contains. Mobil 1 V-Twin rated high for this element.
I also ran it in my Primary and tranny for 1 go around, but found my clutch slipping (slightly) and trans didn't shift well after a few miles.
I currently run HD formula + in the primary, and Mobil 1 75/90 syn gear lube in the trans and I think I've finally got her dialed in.
I also tried B&M Trick shift ATF Syn in the primary for a couple thousand. Initially it was great, clutch worked perfect and stuck now. But within a thousand miles it started grabbing and getting noisy. That's why I went back to HD Formula +.
Everythings good now!
well do as you want. I choose to use V. twin because all the data I've read shows it has higher levels of zinc and other friction reducing additives (HEAT) then cage oils. I'll spend a little extra every 5K. I plan on keeping this ride for long time.
77Tulsa,
My two cent again, I didn't like the 15w-50 in the primary, I didn't think the clutch grabbed as well. I am happy with the 10w-40. But I want to experiment with the 10w-30 next change. I may end up back at the 10w-40.
The 75/95 in the transmission, I feel is just better suited to the types of loading and wear that a transmission gear system sees vs. a formulated motor oil. Again my choices.
If you are going to try the 10w-30, let me know what you think. I won't be getting to this till around December.
