exhaust
Old 09-08-2008 | 04:55 PM
pillows6143's Avatar
pillows6143
Stage II
Default exhaust
Hi new too this so any help would be greatly appreciated, been pulling my hair out trying to figure out what exhaust to put on my road king without losing performence, i herd i can use stock pipes with samson slip ons for improved performence is true or just a waste of time
thanks
Bill
Old 09-08-2008 | 05:38 PM
police stroker's Avatar
police stroker
I did the same when I first got my bike put the rolled thunder miter cut sweet pipes with alot of sound. I used the stock head pipes and had great results with them. It's up to u and what u want dont let others shoot down what you want to do.
Old 09-08-2008 | 06:44 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
Any aftermarket muffler should give you an increase in performance not a decrease. If you went to a true dual setup you would likely lose low end performance but gain top end power.
Old 09-08-2008 | 08:41 PM
hitone's Avatar
hitone
If your RK is a 2007 or 2008 you can change the mufflers for any slipon and not have to change anything else. The ECU will adjust itself to the change and you will have the sound that you want. I am not sure about other years. I have a 2007 Street Glide and have put Kuryakyn Crusher slipons (using the stock headers) with the 13.8/1 XiEDs and a direct replacement K&N air filter. Great sound, runs smooth and strong, better idle and cooler in the heat. I have not had to add an aftermarket black box tuner or use a dyno. The spark plugs don't lie, they look like they should and the performance is most satisfactory. Simple and it works!
Good luck and ride safe.
Old 09-08-2008 | 09:08 PM
itileman's Avatar
itileman
All your questions answered: http://www.rbracing-rsr.com/
Old 09-09-2008 | 06:52 AM
pillows6143
Stage II
thank you all for your time and your input,so many options so little money lol
Old 09-09-2008 | 08:05 AM
dog155's Avatar
dog155
You won't lose enough to even worry about it.No matter what you run, except for drag pipes.You just want to be sure the motor does not run too lean.
StGlideRidr
07-03-2014 08:57 AM
GKersey
07-01-2013 11:46 PM
HaydenHeywoodHayes
03-01-2012 05:58 PM
CopperCanynro
Screamin Eagle CVO Models
11
08-28-2007 11:47 PM
zadmat
02-09-2007 02:50 PM
Quick Reply: exhaust
