Just got a low mileage (500) 05 Road King Custom . I'm noticing a noise in fourth gear when accelerating. Is this common for this trans? Almost sounds like a bad bearing.
Check the tranny fluid. Change to a good synthetic gear oil like Red Line, Bel Ray, Amsoil, Spectro etc. You'll be glad you did. Syn 3 is for Engines, and Formula plus is not as good as the old Semi Synth tranny oil Harley sold as far as smooth shifting and noise go. Hard to believe a bearing went bad in 500 miles unless it was run dry.
Probably same trans as in my 05 Ultra - never heard any trans noise - I use Moble 1 75W90 full syn oil in the trans - change every 10,000 miles. Have like 35K miles on her.
I'll go with normal if it is a whine. My 01 does it and my buddies 03 does it. Consider it your new scoots way of telling you have another gear available. Enjoy the new ride.
