Kuryakyn Panacea install - Requres 2 load balancers?
Trying to install both the front and rear turn signals with the Lapydown Panacea light. It looks like from the directions that two load balancers are required if you have both the front and the rear turn signals. Can someone confirm this?
Also, does anyone have a better set of directions or pictures of the install? Wiring is not a spot I'm super strong at, so all the help I can get is appreciated!
Thanks!
Thanks!
I install the HD LED tail light and Kurakryn led turn signals and Run/Turn/Break. Nothing stated weather I needed two load equalizers or not but with only one my Alarm light would stay on (I do not have an alarm) and after a few flashes the turn signals would get fast. Installed the second load equilizer in the RTB module and everything has been perfect since. So not sure if is text book but I would say you need them.
When I bought my Panacea a year ago they were only shipping one with the light - even though they know you need two to keep the alarm light from coming on. I believe the second one ran me $29.95 from Kury direct, and it's a lot bigger than the one supplied with the unit.
AsahiToro
03-16-2007 11:45 AM
