Help With Security System problem
I have a 2002 EGC, if the key fob was pressed numerous times while away from the m/c, it may be out of sync.
Try this, go to the m/c, ignition off, press and hold the key fob for 10-15 seconds until the security system responds with 2 flashes. If you get this confirmation, the fob is now back in sync with the security system and should work properly.
KiloGolf4
08-26-2012 06:10 PM
