Steering head bearing grease
I just checked my service manual while watching the hurricane out the garage door. It says nothing about the bearings being sealed. In fact, it says to inspect the races for pitting during dissemble. Something ya can't really do with sealed bearings and expect to use them again.
The manual also refers to "Special Purpose Grease" rather than just grease, so I would presume this to be something that didn't melt or run as conventional grease would.
As far as grease goes there are a few different kinds. Chassis grease which is some what one the lower scale of longevity as there is no heat in that application so it tens to melt/drip/fly off if used in the wrong application.
Then theres EP grease (check the tube label) This means extreme pressure application which could be used in neck bearings as it has a higher melting point so it would drip less. There is also HI Temp wheel bearing (and a seperate kind for disc brakes) It will take hi heat but melts and is semi fluid so it can keep both inner and outer bearings in a wheel hub lubricated.
This is bad for neck bearings at least the top one anyway, because the grease will tend to droop down to the lower bearing and come all over your fender.
Silicone type maybe good, I would have to read the MSDS to find its servicability?
Im just gonna use the same crap I have for all my daily drivers hot rods and wheel barrows
Im not buying it needs any special kind of grease but it needs grease... Go to sears and you can get an air powered grease gun if you have a compressor and make short work outta it. Im betting the stealer didnt even grease mine but we shall see. Oh ya i think lincoln electric makes a battery powered grease gun too..
Dave
Dave
