Moisture on Gauge Lens?
Old 01-19-2011, 02:39 AM
CroK's Avatar
CroK
CroK is offline
Moisture in guages? It goes away eventually, then it will return again...
Unlike the little moth that some how found it's way into my speedometer. It died about three days after I first noticed it. Now, it lays in the bottom of the glass awaiting some miracle to breath life back into it's dried up lungs...
My coolie never seems to keep the moisture off my beer either. Some of that could be slobber tho...
Old 01-19-2011, 02:58 AM
0734's Avatar
0734
0734 is offline
kato.....send me my case of beer! First time I asked years ago with my first bagger....dealer told me "that's normal".Every one I ever had did it. Don't worry about it....soon as it warms up enough it will go away.
Old 01-19-2011, 04:32 AM
Olde Skool's Avatar
Olde Skool
Olde Skool is offline
Originally Posted by parachuter
I know this sounds crazy, but I did not have trouble with fogging gauges until I installed the chrome trim rings around the gauges. Go figure.
Not only do my gauges fog up at times, now my glasses are all fogged up after looking at your avatar. I hate it when that happens...
Old 01-19-2011, 06:03 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is online now
Received 7,168 Likes on 3,676 Posts
Warrarnty won't cover this.
Old 01-19-2011, 08:00 AM
Twoshots's Avatar
Twoshots
Twoshots is offline
Default spyder in MY speedo
Here is a strange for you, I had a 83 Wing that got one of those fuzzy black spiders about half dime size in the speedo. little bas---d built a web on the peg where the needle rests . would not let the needle come up when you started to role. Had to take a little bit and drill a small hole between the glass and face of the speedo and insert a small florists wire whith a small hook on it and pick the web out , then resealed the side of the speedo with calk.
heizlod
2018+ Softail Models
03-14-2019 02:19 PM
ottawaair
04-13-2015 12:13 AM
JonGolden
06-03-2014 11:23 PM
Tripwire1
08-24-2010 12:53 PM
leegm
VRSC Models
05-12-2008 08:25 PM
Quick Reply: Moisture on Gauge Lens?
