PSI, FLHX air shocks?
Old 09-04-2008, 02:17 PM
cHiLi_11's Avatar
cHiLi_11
cHiLi_11 is offline
Default PSI, FLHX air shocks?
So my question is what psi do you guys typically run solo? What ever the psi from the dealer is sucks. I am 210 lbs at 5'10" and I always bottom out on the freeway with the smallest dips. I was gonna check/fill them but then a friend mentioned not to use my air compressor because I might blow out the line. He said Harley makes a hand pump for them, what do you guys think? Also what psi do you run with a passenger, my lady is right around 125 lbs? Thanks for the help.........
Nick
Old 09-04-2008, 02:22 PM
jdreed520's Avatar
jdreed520
jdreed520 is offline
I agree you dont want to use your aircompressor it will blow out the shocks. Trust me i did it. Just bite the bullet and go by the hand pump. Also look in your book for the max pressure. Just adjust it up about 5lbs at a time until you find that feeling you are looking for.
Old 09-04-2008, 02:25 PM
Reverend's Avatar
Reverend
Reverend is offline
Try 20psi...good starting point...and the gauge is worth it's weight in petrol
Old 09-04-2008, 02:27 PM
cHiLi_11's Avatar
cHiLi_11
cHiLi_11 is offline
Is that 20 psi solo? The harley chart is saying 10 psi up to 200lbs?
Nick
Old 09-04-2008, 02:29 PM
mtairy biker's Avatar
mtairy biker
mtairy biker is offline
i run 15 psi for solo
Old 09-04-2008, 03:01 PM
Chief X's Avatar
Chief X
Chief X is offline
Former Sponsor
I typically run 22 psi alone or with my girl. The handpump (for the harley...) is worth the money!
Old 09-04-2008, 06:04 PM
leohd's Avatar
leohd
leohd is offline
I am running 10 solo and 15 with passenger
Old 09-04-2008, 06:16 PM
Ultra61's Avatar
Ultra61
Ultra61 is offline
18 psi...I am 210lbs
Old 09-04-2008, 06:39 PM
candyx's Avatar
candyx
candyx is offline
I run zero psi in my shocks,but then again there in a progressive box sitting on a shelf.Springs were good in 1903 and i must say mine work great in 2008, air is for tires.......
RjCapp's Avatar
RjCapp
RjCapp is offline
10 PSI solo 195 lbs
15 2 up 195 + 135 lbs
08 SG
Quick Reply: PSI, FLHX air shocks?
