Installing the Adjustable Rider Backrest?
Old 03-26-2006 | 03:38 AM
HogHal's Avatar
HogHal
Default RE: Installing the Adjustable Rider Backrest?
Okay, I just installed my sundowner seat and the adjustable backrest. I tried the seat before putting on the backrest, and loved it! But, with the backrest on, even in the full-back (most upright) position, it crams me into the tank. WTF, What did I miss? And thanks spartns for the tip about shimming it so it doesn't wrinkle the seat. Thanks for your help folks...
Old 03-26-2006 | 08:47 AM
Grover's Avatar
Grover
Administrator Emeritus
Veteran: Marine Corp
There are 4 sets of holes in the bracket that mounts below the seat so you can adjust the fore and aft position for short or long legs.
On the rear side of the backrest, near the bottom of the covering material is a small hole that allows access to a 3/16 allen head screw. You can adjust this screw to adjust the forward and backward tilt of the backrest pad.
Old 03-26-2006 | 12:58 PM
R1Geezrglide's Avatar
R1Geezrglide
ORIGINAL: HogHal
I have the same problem. The Wife and I went on an all day ride to Milwaukee during which I adjusted it every way I could. I eventually stuffed it in the saddle bag. The problem is it creates a bump in the seat that pushes me foward about and inch. Apparently there is a hump in the seat pan (stock '02 FLHT seat) that makes me feel like I am sitting on a padded pipe. Poorly designed IMO.
Old 03-27-2006 | 12:41 AM
HogHal's Avatar
HogHal
Thanks Grover, didn't know about that adjustment. I didn't get any instructions with the backrest.
R1geexerglide, yep, that one spot presses that hard metal brace through the seat into the small of the back...
thanks folks...
Old 03-27-2006 | 09:18 PM
bikerjohn80's Avatar
bikerjohn80
I just put one on my E-glide. I have a "tall-boy" seat and even all the way back the rest pushed me too far forward the rest slid in and stayed at about a 45 degree angle toward the front. So I took the mount off cut the front and sides and remouted it and adjusted it. Pulled the seat back off and I needed about an inch more in height toward the front I welded a piece of plate to it and extended the toungue about and inch and it works GREAT make it all feel like an easy chair lol lol
Old 12-27-2008 | 09:24 PM
bsea's Avatar
bsea
This is an old thread, but I had to post a big thanks to everyone who provided input. I got one of these for Christmas and, frankly, there was a devil to pay getting in installed. Did a search here and lo and behold, here was the answer to my problem. Read up, went back to the garage, and presto, all done. Thanks much to everyone, is this a great forum or what!
Bill
smurfsdad
06-24-2012 10:26 PM
Limit
06-14-2012 11:36 AM
NewAge
01-15-2012 01:43 PM
monstead
04-18-2009 06:56 PM
2CMan
01-05-2007 02:50 PM
Quick Reply: Installing the Adjustable Rider Backrest?
