red line
There is no redline just a rev limiter. You'll know when you get there, the engine will sound like it cutting out as the fuel is shut off until the RPMs drop back down. Try it for yourself and let us know where it happens.
Supposedly you can't hurt the engine because the ECM won't let you. In theory that it.
Steve
Steve
wierd - my tach has a redline after 5k RPM -- i did push it but as mentioned above - ECM will cut out fuel and it just bounces at 5200rpm till u back off throttle. Doesnt sound like the bike like it there. I had Stage 1 download - i wouldnt even think of going to 6200RPM..
as STage one is supposed to increase the REV limit.
Location: Beverly Hills, Fl. Swimmin pools. Movie stars
It actually doesn't hurt to bump up against the rev limiter once in awhile after you have the engine break-in period done. It kind of reminds the engine that it is capable of running at that high of an rpm. I run mine through the gears every once in awhile and make a point if hitting the limiter....don't hold it there, but hitting it, then shifting or backing off won't hurt anything.
