Road Glide Wind Management
I just converted a 2006 roadglide to a Batwing fairing.I rode softails before so these two comparisons are the only two touring bikes I have been on. My opinions are based on both fairings on same bike with same variables. 1. Wind buffeting is a lot worse on Batwing. 2. Crosswinds are crosswinds same on both. 3.Wind buffeting over shield, Roadglide with short shield was horrible and I tried them all. Roadglide with Clearview adjusted so you just see over it awesome. Batwing with short shield horrible. batwing with 12" shield awesome. Bad weather I found the batwing far far superior. You are to far away from fairing on roadglideand the weather goes around fairing and hits you more than batwing. Also your hands are protected behind fairing on batwing. Headlight all the seeing where you are going is crap. If you are doing more than 5 miles an hour you are leaning a bike and the headlight stays pointed ahead regardless of fairing. Under 5 miles an hour who cares.
I switched fairings because I did not like the Roadglide with the tall fairingvand it was brutal with any short shields i tried.So if you like a tall shield it all boils down to taste. If you want a short shield I would suggest you rent or borrow a Roadglide and do an all day ride before making a decision.
Hope this helps.
Hope this helps.
Love my Road Glide but had the helmet buffeting problem. I'm 6' tall so while having my other accessories put on today from my deal they also put on a stock shield 3" taller and now it's great. I have never ridden a batwing but am very happy with my RG. Feels like I'm riding around in an armchair it's so comfortable.
Yes, the CV is raked back more than stock. Quite a bit more actually. To bad I don't have pics to compare.
