Swapped the 21" Metzeler for an 18"-Results
I just received my .95 kg kit. Here is what was recommended to me for the 21" set up on a 08 FLHX. Lowered 1" of course.
Emulator 2 turns / 40 lb/in springs
Pre Load 1 inch
Oil Level 6" (152 mm)
Fork Oil 15W
I have no idea why 6" (152mm) vs the 6.3" (160mm) on the instructions. Again I have no experience with the settings. I need to get it right the first time!
G XXX
Why did you decide on 10W?-It's the weight we used with the 21" and the one the Master Race Tech installer suggested for the softer ride I was hoping for with the 18
How much do you weigh?-190
Have you tried a setting higher than the 1.5 turns?-Not yet, but likely will
Do you think changing the preload requires adding spring tension to the emulator?-Not sure about that one
Pre Load 1 inch
Fork Oil 15W
G XXX
