LED Bulbs Turn Signal / Load Equalizer Required?
Old 04-25-2009, 05:08 PM
CW4_131A's Avatar
CW4_131A
CW4_131A is offline
Yup, ya need one.
Some LED's have the equalizer in the attachment to the standard bulb insert. Some don't. The one's that don't need an equalizer.
Old 04-25-2009, 08:10 PM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
Badlands Generation III Load Equalizer plug-n-play module = $69.95 delivered
I'll be ordering one this week.
Steve
Old 04-25-2009, 08:36 PM
BigDaddyMike's Avatar
BigDaddyMike
BigDaddyMike is offline
Steve
After having trouble putting my LEDs from my 05 to my 09 and using several different LEs I bought this one. Mounted under the seat and it DOES NOT get hot...read...can use flashers all day if you want. Can also use as many LEDs with this baby and never need another equalizer....Really was plug and play too!
Old 04-25-2009, 09:08 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
Originally Posted by hogdoctor
1156 bulbs are only for bright use. 1157 has a dim filament for a marker light as well.
They require differnt sockets, as the 1156 only has one contact button on it and 1157 have two. I changed my rear turn signal housings to match the front, so I"m running 1157's all around. FTR I've never seen a 'dual filament' 1156.
Hogdoctor
what he said. Different nubbies on 1156 and 1157
Old 04-25-2009, 09:09 PM
IAMSWUTIAMS
I just installed LED bulbs front and rear in my directionals, and my TSM/TSSM is not liking it at all. Same bulbs all around, but they are blinking 3-4 times normal and they go super fast. And the Security key is staying lit in the dash as well.
Load Equalizer?
Steve
You need one
Old 04-26-2009, 08:11 AM
hogdoctor's Avatar
hogdoctor
hogdoctor is offline
Default rapid blinking after bulb change...
Load Equalizer?
Steve
I'm not 100% certain about this, but I remember something about after having replaced a blown bulb, you would have to convince the module that things were back to normal, by flashing the left and right turn signals in sequence, I think it was just back and forth from left to right about ten times or so. I don't have the paperwork to back it up, but it's worth a try.
Maybe it will stop the rapid flashing without the load equalizer and you can put that money toward beverages...
Hogdoctor
Old 04-26-2009, 09:14 AM
TheShrink's Avatar
TheShrink
TheShrink is offline
You need a Load Equalizer that is security comp. BADLANDS! Just get the Illuminator and that will fix everything.
Andrewwayne
04-29-2017 09:36 AM
acd118
11-30-2015 11:53 AM
jbersaglia
07-03-2014 11:30 AM
ndmick
EVO
15
05-10-2014 08:12 PM
JR-Boston
05-12-2010 06:37 AM
Quick Reply: LED Bulbs Turn Signal / Load Equalizer Required?
