Lowering a RK Custom
Old 08-31-2008 | 03:52 PM
bikerchic's Avatar
bikerchic
6th Gear
Default Lowering a RK Custom
I would like to lower my RK Custom. I'm sure someone out there has done this if so did you use a kit and if so from where?
Old 08-31-2008 | 05:03 PM
skratch's Avatar
skratch
i just used 11-1/2 inch progressive 440s on the rear. lowered it enough that i could flatfoot it at a stop. how low did you want to go?
Old 08-31-2008 | 05:10 PM
blueflht's Avatar
blueflht
12" street glide shocks, or arnott air ride kit for the rear . race tech or progressive suspension allows a 1 to 2" drop in the front wouldnt recommend the lowering blocks available on the net. decreases the needed travel angle for the shocks and issues with the fender bottoming out on the tire are numerous
Old 08-31-2008 | 05:13 PM
08CrimsonClassic's Avatar
08CrimsonClassic
Contact Ron at BitchenBaggers.com . Or just check out his site for some info.
Old 08-31-2008 | 06:37 PM
skratch's Avatar
skratch
blue, the road king custom already has the 12 in shocks, same as the street glide. thats why i went with the 11-1/2 inch progressives. i don't know enough about the arnott air ride system, too much for my wallet!
Old 08-31-2008 | 08:29 PM
bikerchic's Avatar
bikerchic
6th Gear
Blue, like skratch said I already have the 12in shocks, I would like to go down 1-2 inches. With the progressives how much did that lower it half inch or so? Maybe I'll just go with taller boots.
Old 08-31-2008 | 09:02 PM
skratch's Avatar
skratch
try both, but really, that extra 1/2 inch from the progressives really made a huge difference. also, what seat are you using? if its stock, then thats gonna make a huge difference also. and as a matter of fact, i just happen to have a corbin classic solo that fits the road king custom. i had to get another seat because the corbin is not compatible with the solo tourpak rack. pm me if you are interested in it.
Old 08-31-2008 | 10:27 PM
stevepacman's Avatar
stevepacman
Same here. Progressive 440's plus a HD lowered front end. I plan to get an Arnott Air Ride so I can get a little lower without bottoming out. Ya gotta admit any bike looks good slammed!
Old 09-02-2008 | 06:19 PM
skratch's Avatar
skratch
just that extra 1/2 drop makes my bike look badass. course, i could be just a little biased
Old 09-02-2008 | 07:10 PM
eglinski's Avatar
eglinski
I have the stock seat on my RKcustom as well, Is there another 2-up seat that fits... that is lower? hard to believe from looking at the stock seat and frame lines that it could get much lower
also, are the 11.5 in progressive 440's air shocks?
Quick Reply: Lowering a RK Custom
