Notices
Michelin Commander Mounting Issues ???
Old 08-31-2008, 06:38 AM
NCCopBikeRider's Avatar
NCCopBikeRider
NCCopBikeRider is offline
Exclamation Michelin Commander Mounting Issues ???
06 Cop Glide
Cast Wheels
Michelin Commander MU 85 Rear Tire
Left bike at dealer before coming to Fontana for the Nationwide and Cup Races to have rear tire replaced.
Bought the tire from Servicing Dealer
Service writer called yesterday afternoon saying that she had a bulletin saying this tire should not be used with cast wheels. Said tire had to be mounted with a tube on spoked wheels.
Michelin site does not have any warning about this.
This site does not seem to have issues (used search and did not find anything)
Thanks
Buells to Alaska ALCAN 5000 2010
Old 08-31-2008, 06:54 AM
NoKenDo's Avatar
NoKenDo
NoKenDo is offline
4000+ miles on 06 SG stock cast wheels.
No problems. Love the tires
Old 08-31-2008, 07:35 AM
hdman's Avatar
hdman
hdman is offline
Got front and rear Michleins on 06 EG. No problems... Love the grip...
Seems you got the wrong information from a unreliable source. My EG
does have cast wheels BTW................ hdman
Old 08-31-2008, 09:19 AM
NCCopBikeRider
Default Dealer's Service Writer Gave us the Information via Phone
Thanks
Appreciate the input
Partner has had three (3) sets on his high mileage Road Kink with no issues
Will report back later
Old 08-31-2008, 09:26 AM
Medicfrost's Avatar
Medicfrost
Medicfrost is offline
Contact Michelin, and ask them about this.
Old 08-31-2008, 12:07 PM
cts1950's Avatar
cts1950
cts1950 is offline
I have commanders on my ultra with cast wheels. The local dealer had issues getting the bead to seat. It appears the the inner bead fits tighter than the Dunlap's or others. They tried for 5 hours to get it to seat and failed. I asked if I could try it at home, they were glad to hear that because it was quitting time. Once I got home and got my hose and valve out I had it mounted and aired up in 5 minutes. What did I do different. First my compressor is set at 175 psi. there's was at 135 psi I was able to put more cfm into the tire. I used a valve connected to a hose that would tightly fit over the valve stem with no restriction. I also did not have to hold the valve open by hand leaving me both hands to hold the tire to get the best initial seal against the wheel. I took the wheel back the next morning to get it balanced which they did for free I think they were imberrased.
Old 08-31-2008, 01:07 PM
NCCopBikeRider
Interesting
Thanks
Old 08-31-2008, 01:14 PM
Mathews2's Avatar
Mathews2
Mathews2 is offline
I Mounted both the front and rear Michelin on my SG, seated the bead with no problem with 120 PSI compressor.
Old 08-31-2008, 07:39 PM
NCCopBikeRider
Appreciate the update
Will pass on to dealer in the AM
Old 09-01-2008, 07:26 AM
NCCopBikeRider
Service Writer insists they have a bulletin form HD not to mount this tire on cast wheels
Sounds like BS
The Parts Dpeartment at the Delaership sold us the tire, and it is an approved HD replacement for the Cop Glide
Any input will be appreciated.
Thanks
Quick Reply: Michelin Commander Mounting Issues ???
