got up this morning and al i get is a click from the starter battery fully charged rode home last night 3 hour drive no hint of problem thanks for any help
Give us a bit more info....like what year/model bike you have. Did it do anything strange last time you road it? Did you or anyone else touch or "work on" the bike after the last time you road it?
it is a 07 ultra classic rode it home last night from mil105th any how about a 3 hour ride no problems whats so ever checked battery the termals are tight checked fuses had the battery checked out at the dealer they said it is ok no new ork done on bike
In the past I have had almost new batteries fail due to a loose plate that shorts out inside. This condition can sometimes be intermittent and the battery can sometimes read as full charge. If your ground is not loose I would suspect a battery failure.
Does your fuel pump run? Does your engine light come on and then go off? Your ground is connected to the two allen bolts at the back of the starter. You can try pulling your starter relay and system relays out and check for corrosion. The system one is on the right side under the side pannel.
