fairing soundproofing
I had trouble finding it the first time. Use a hyphen, r-blox. I bought some. Can't hurt to try it. I would like a little more bass anyway.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270268945624
Dynamat is very light weight. Here's link on ebay to 4sq ft of Dynamat Extreme for $11.99 plus add shipping. That should be enough to do the job !
http://cgi.ebay.com/10425-DYNAMAT-Xt...3286.m20.l1116
My experiances with Dynamat is when hot it looses its ablity to stay in one spot, and needs re-gluing with something. I would think it would be even more **** to loosing its grip in a fairing from all the road vibrations over that of a trunk or door panel of a car.
Having never used inside a speaker cabinet (basicly what your fairing is) I'm not real sure how well that will work over batten type insulation.
Any custom speaker enclosure builders out there?
I used a product called Fat Mat to do my aftermarket fairing. it seemed to make the bass better and a few small rattles went away. it was fairly cheap too. we ended up doing it to my son's streetglide and it made a world of difference with his bigger speakers and amp.
here's where we bought it from: www.fatmat.com
the rblox isnt heavy at all and when installed and rolled it sticks like cement. as best i can tell from research and smell its butyl rubber not asphalt. i also used 5 sq. ft to do my fairing so you might be short on the dynamat. at 19.99 for 10 sq. ft the r-blox is the way to go. split it with a friend 20$ each!
karz10
Audio Systems
05-06-2019 11:58 AM
