'09 Exhaust: Slip-on or True Duals?
Old 09-16-2008 | 09:31 AM
1potter1's Avatar
1potter1
The real reason we want to add the stage 1 kit. Is to avoid the lean, burn the top off the piston condition, set by the epa.
Old 09-16-2008 | 01:20 PM
flyingace's Avatar
flyingace
You wont get what you want.
The Harley Stage 1 upgrade (intake and ECM reflash) is STILL EPA compliant. The flash only compensates for the intake. In the end, it puts you right back at the same lean condition, just compensated for the free breathing intake.
Before: lean
Change intake: extra lean
Stage 1 flash: lean
If you want to get rid of the lean condition, you need some form of tuner.
Old 09-16-2008 | 05:27 PM
geeded's Avatar
geeded
I believe that the new '09 exhaust is probably a very good unit. The 2-1-2 is very similar to the "X-pipe" that so many fast cars use now. Improves scavenging and low end torque. Seems this new system will do the same. Also, I think it looks great and stops my wife from frying her legs.
Cheers, geeded
Old 09-16-2008 | 07:19 PM
oldbag's Avatar
oldbag
Cheers, geeded
I agree completely. The new style exhaust looks great and should be great performing. I installed Screaming Eagle mufflers and am very happy. Saved a lot of money too.
Old 09-16-2008 | 07:37 PM
duglaura&flhti's Avatar
duglaura&flhti
Default Trueduals
Hey brother, I have the reinharts duals and I think they have a great sound,but sound....exhaust pipes/sound are so passive and everyones ear/sound is so different....you have to hear each sound clip from other HD setups like I did to find that sweet sound you want...Good luck.D
cajun1957a
06-15-2019 05:55 PM
Harpoonman
05-23-2009 05:37 PM
deadbug
04-16-2009 09:42 AM
Chrome Sweet Chrome
08-16-2008 05:54 PM
Lawdawg
05-22-2006 06:19 PM
Quick Reply: '09 Exhaust: Slip-on or True Duals?
