Loose shift linkage, but on the trans side
Old 11-18-2011, 08:49 AM
Lakerat's Avatar
Lakerat
Lakerat is offline
Temporary fix if your splines are shot is to drill and tap 1/4-28 through the lever into the shaft for a set screw. Not a permanent repair but it could get you through for a while.
  #32
Old 11-18-2011, 11:16 AM
elauee1's Avatar
elauee1
elauee1 is offline
On a 2010 road glide my lever is tight on the trany shaft by not all the way seated against the trans. Should a loosen the bolt and slide it closer or just leave it. THANKS
  #33
Old 11-18-2011, 11:44 AM
SIDECAR BOB's Avatar
SIDECAR BOB
SIDECAR BOB is offline
the bolt passes thru a groove in the shaft to keep it from moving in or out
you cannot slide it in farther or tqake the lever off without removing the bolt totally out of the lever unless either the bold or shaft is messed up
tsigwing
04-05-2019 07:14 AM
mechanicalman
10-21-2015 09:21 AM
Guma
08-22-2006 11:14 PM
barhpr
08-18-2006 08:07 PM
89FLHT
05-23-2006 03:05 PM
Quick Reply: Loose shift linkage, but on the trans side
