IDS Bearing Failure
IDS Bearing Failure
Replacing tires on 07 Ultra and found that the bearing on the IDS hub is bad. It is a double ball bearing assembly. Has anyone crossed this bearing over to an aftermarket bearing yet? Seems to me I should get more than 14K miles out of this bearing. Doesn't look like the bearing had enough grease in it because there is a lot of metal transfer in it caused by heat.
Didn"t have any indication at all. Was replacing tires when I found it. I'm going to a bearing distributor and see if they can match the bearing up. There has been too many failures of this bearing to be anything but defective bearings. Something else I noticed was the belt is wearing the pulley more than I would have guessed.
Bought it at the dealership and installed myself. Went to bearing distributor and found that HD is having this bearing made for them because it has a 1" bore diameter. So what this means is this bearing will only fit 2007 bikes. In 2008 when they went to ABS they changed the axle diameter to 25mm. I have about figured it out that every rear tire I put on the bike I will need to replace this bearing. Good thing it's only $22.00.
